I am being forced to leave Plusnet due to phantom traffic shaping .
- I am being forced to leave Plusnet due to phantom ...
25-01-2020 12:07 AM
After many months of slow down load speed with hours spent on the phone to plusnet residential tech support , the people in the business side of plusnet have found that my line is being " throttled down" by 75% , with no explanation as to why ? This generally happens at weekends Friday evenings to late Sunday night , it can last all week end ,or just at random times .
has any one else been in this situation ? And if so was it sorted out
Re: I am being forced to leave Plusnet due to phantom traffic shaping .
25-01-2020 4:53 PM
Thanks for your post @Mrblue861
I'm sorry to see you're experiencing speed problems. We haven't had traffic management on our network for almost 3 years now, at least for residential Unlimited packages so we're not throttling your speeds.
I've tested your line and the tests aren't showing any issues with your speeds as shown below:
GEA Test Detail | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
While your connection is dropping fairly frequently I understand from reading the notes on your account that you're rebooting your router to try to fix the problem you're experiencing. I'd actually recommend against rebooting your router too frequently because that's going to eventually have an adverse affect on your broadband connection.
Notes also suggest that your devices are connecting over WiFi, so it may be that you're getting a lot of wireless interference at peaks times slowing down your throughput making it seem like you're being traffic shaped.
So I can get a better understanding and try to get to the bottom of this with you, I've got a few questions. Are all and/or the majority of the drops shown above a result of you rebooting the router? Do you experience slowdowns at peak times on a wired connection, i.e. a computer plugged directly into the router using an ethernet cable?
If your speeds are slow on a wired connection, to investigate further can you run the BT Speedtester at https://speedtest.btwholesale.com with no other programs running at the same time such as streaming, general browsing and the most common one is antivirus programs downloading updates in the background.
Once the initial result is completed please click Further Diagnostics then type your phone number in and click run diagnostic test. This will run a test and send the results to the BT server for investigation.
Let me know how you get on.
25-01-2020 5:19 PM
I have been there and done all the tests as you suggest , I have been in contact with Tom who works on the Business side of
plusnet and he has confirmed the download speed is being " throttled " traffic managed or what ever by openreach , it took him
a few seconds to change the line profile , and after resetting the router this set the line speed to normal , Tom is not sure if openreach will be able to fix the problem , however same evening while watching Amazon prime , the tv picture suddenly degraded , sure enough a quick speed test confirmed that the line speed had dropped from
65 to 69 down to 20 mps , finished watching the program, reboot router , like I said before this normally happens weekends , or in the evenings sometimes rebooting the router works sometimes it does not , same fault occurs using plusnet hub one , bt hub 6 and TPlink 2800 , wired or wireless same fault , ..
25-01-2020 5:22 PM
Screen shots not opening on here ... will try another
25-01-2020 5:35 PM - edited 25-01-2020 5:36 PM
Thanks for getting back to us @Mrblue861
Sorry for any confusion, I can confirm that you are not traffic shaped because there is no traffic management for the package you're on. What previous advisers may be referring to is the 'connection profile' on your account which will restrict your throughput if it's set below the bRAS profile of your line.
The only reason this profile may change is if your connection drops which will force your router to physically re-sync to the equipment at the cabinet at a new speed, that's something we've got no control over.
If you completed that speed test on a direct ethernet connection with no switches or powerline adapters in place and there wasn't anything using your broadband at the same time we'd need to arrange another engineer to investigate further. Let me know if you're happy with this and I'll be happy to get the ball rolling on this.
[edit]
Actually could you also leave your router on for 72 hours without rebooting it? I'd like to then check back and retest your line and we'll go from there as this should hopefully give us an accurate reading of what's happening with your line.
25-01-2020 5:52 PM
What about a few Thinbroadband speed tests to see if there is a difference in multi thread and single? Could indicate a congested exchange?
25-01-2020 6:07 PM
So I have had two engineer visits already ..so what is a third visit going to look at ? If you can walk me through how to upload a photo on here I will show you BT's line test result ...
25-01-2020 6:56 PM - edited 25-01-2020 6:58 PM
Looking at the S-VLAN utilisation data there's no congestion seen at the exchange, but from looking at the reactive repair tool(RRT) data we can see the line is erroring and it's detecting a potential line issue.
My recommendation is to leave your router switched on for the next 3 days without rebooting it. We should then be able to get a more accurate picture as the forced drops caused by the reboots may be causing the errors we're seeing.
After the 3 days I'll re-run the tests and we'll see where we are. It's always possible that the line issue and errors we've detected isn't caused by the reboots of the router but at this stage I'd like to start ruling things out.
I believe you've already uploaded an image on to your post, if you want to upload anymore images or photos you'd do that in pretty much the same way using the Insert Photos button when making your post.
25-01-2020 7:18 PM
JPEG upload ...
25-01-2020 7:29 PM
Thanks, this just shows you're getting a slow throughput. While it's good to see it doesn't really tell us where the issue lies.
Could you just confirm if all and/or the majority of the drops pictured above are when you're rebooting the router or if they're happening by themselves? Conscious about which path we go down to try to resolve this.
25-01-2020 7:37 PM
Slow speeds can be at peek time or just occur at totally random times, sometimes rebooting will reset speed sometimes not .
when I went on line for the first time today ( 12:00 ish) download speed was in the 19 - 26 range , router reboot fixed it , but this slow speed default can last 2-3 days regardless of any amount of reboots .
25-01-2020 7:54 PM
Thanks for the detail,
Seems to rule out congestion if you're having issues at non-peak times as well.
I'd like to see what our data looks like without frequent reboots of the router although the odd occasional reboot should be OK.
The data is always about 24 hours behind so to get a couple of days worth of it I'll check back on Wednesday at the latest.
