I Appear To Be Back On A Very Flaky 40/20 Connection
FIXED- Subscribe to RSS Feed
- Re: I Appear To Be Back On A Very Flaky 40/20 Conn...
03-01-2017 2:53 PM
http://www.thinkbroadband.com/speedtest/results.html?id=1483453465850368555
When I upgraded to fibre a year or so ago I was quite happy with a solid 40/20 connection. Then PN decided to change this to 55/10. I first had a solid 40/10 connection, then PN got their act together and I had a good solid 55/10 connection with which I was again content.
Now the gremlins appear to have got back in and I appear to be back on a very flaky 40/20 service that I am not happy with.
I am running an Unlocked HG612 modem plus an Asus N55u as a Router. As you can see from the these Telnet stats 55/10 should be easily attainable.
Note that speed tests are via Ethernet cable.
Are there any PN staff around that can please have a look at my connection?
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 25125 Kbps, Downstream rate = 71904 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 72653 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 6.3 8.9
Attn(dB): 14.4 0.0
Pwr(dBm): 13.8 4.5
VDSL2 framing
Bearer 0
MSGc: -6 20
B: 243 239
M: 1 1
T: 0 64
R: 10 0
S: 0.1069 0.3819
L: 19001 5028
😧 8 1
I: 254 120
N: 254 240
Q: 8 0
V: 0 0
RxQueue: 56 0
TxQueue: 14 0
G.INP Framing: 18 0
G.INP lookback: 14 0
RRC bits: 0 24
Fixed! Go to the fix.
Re: I Appear To Be Back On A Very Flaky 40/20 Connection
03-01-2017 3:01 PM
I would take the Thinkbroadband stats with a pinch of salt at the moment, they seem to be very strange - try an speedtest.net and see how it shows on there.
Your sync speeds seem very good, and not limited to 40/20. Might also be worth having a look on the BT Wholesale test site, and see what it shows, it will have the limits on there.
03-01-2017 3:27 PM
https://community.plus.net/t5/Fibre-Broadband/Odd-TBB-test/td-p/1393324 have a read here
03-01-2017 3:59 PM
These are the results I am getting from TTw and Speedtest.net.
03-01-2017 4:18 PM
Hi @Baldrick1
This does seem quite strange, your account is showing that the speed was updated by a Delta Report from 55Mbps to 40Mbps.
I've now manually changed this back, so if you disconnect the router, reconnect and then test again, you should be seeing the 55Mbps speeds as expected.
03-01-2017 4:33 PM
Thanks Harry, upload is even flakier now but at least I've got 55Mbps download back.
http://www.thinkbroadband.com/speedtest/results.html?id=1483460945316479055
03-01-2017 4:37 PM
Moderator's note by Mike (Mav): I have changed the fix to @HarryB as per message #5.
Forum Moderator and Customer
