Huge numbers of CRC errors in small time periods
- Huge numbers of CRC errors in small time periods
02-07-2015 1:40 PM
Just had 36000 CRC errors in a small space of time which caused a disconnect from game server. Is the heat affecting lines or something or is there a fault on my line.
Message 1 of 7
(1,062 Views)
6 REPLIES 6
Re: Huge numbers of CRC errors in small time periods
02-07-2015 2:51 PM
Message 2 of 7
(682 Views)
02-07-2015 3:45 PM
44,000 in 6 hours uptime.
Message 3 of 7
(682 Views)
04-07-2015 9:59 PM
Back with a vengeance again today, this morning I had 3000 errors, now I have 165,000. When the spikes occur in the thousands my connection drops for 10-15 seconds before coming back around. Something is majorly wrong somewhere as I never had this issue in 3+ years on BT Infinity...
Message 4 of 7
(682 Views)
05-07-2015 9:31 AM
I'm now at 261,000 CRC down errors in just a 2 day period. Nothing in the household has changed to cause interference between the time I was with BT and now with plusnet.
The engineer who came out said something about the telephone line should be replaced but after testing it he didn't think it needed replacing, maybe he just couldn't be bothered?
The spikes occur in thousands and are causing the connection to lag out for 10-20 seconds when they happen which is very annoying if you're streaming anything or gaming.
Message 5 of 7
(682 Views)
07-07-2015 10:07 AM
Ignore
Message 6 of 7
(682 Views)
07-07-2015 6:26 PM
TBB graph after trying a reboot.
I'm guessing nothing can be done about this as it seems nobody wants to reply?
Gaming with this constant packet loss is as you can guess, rather annoying.
Message 7 of 7
(682 Views)
