HubOne AlwaysOn VPN
rjenkins123
HubOne AlwaysOn VPN
Hello,
Wondering if anyone is able to help. My work has switched from a Citrix based VPN to using Microsoft's "Always On" VPN technology (I understand from IT this uses ikev2 protocol).
Since this change, I cannot connect to the work VPN. Luckily I can still use the old system but they are phasing this out so I need to get to a solution.
This all works no problem if I tether my phone to my PC, hence the problem is definitely either at my Router or with PlusNet more widely.
I have spent an hour with our IT server guys, and they believe they have exhausted everything they can do:
  1. Reinstalled all the software, no joy
  2. Changed software settings on the VPN, no joy
  3. Restarted the router a couple of times to generate 3x new IP addresses, no joy
  4. Temporarily disabled the firewall on the router, no joy
They have said that they cannot think of anything else their end to try - so have suggested I reach out to PlusNet. I notice there have been a few previous threads along these lines, but as far as I can tell most of them don't seem to ever be fully resolved - is a Static IP worth trying?
Thanks in advance for any help!
Richard
7 REPLIES 7
rjenkins123
Re: HubOne AlwaysOn VPN
Just some further information:
My IT support have checked their firewall logs, and cannot find any requests coming from (any of) my IP requests. Hence they are confident that the problem lies somewhere between my PC and their servers. They also do not use a blocking list of IPs
Fixes: 394
Very likely. The routing is different for static IP's.
Fixes: 1,600
Hi Richard, sorry for the issues you're having with your work's VPN and welcome firstly to our community forums.
I've added a static IP onto your account now, could you reboot your router and try again? Let me know how it goes.
rjenkins123
Hi Both,
Thanks for your help and for adding the static IP.
Unfortunately - this seems not to have fixed it. I have however, by accident, discovered that the problem GOES AWAY when I use the wireless connection. My normal connection is over ethernet through a powerline adapter. I have also tested plugging my machine into the router directly (ethernet port 1) however this does not work also.
This suggests to me some form of port issue with the router?
Thanks!
Richard
Fixes: 1,600
Hi Richard,
Ah that's disappointing, I think we can rule out a network issue our side in that case.
I've removed the static IP now so once your connection drops next you'll go back onto an IP of a dynamic range.
Definitely looks like you've got to the bottom of the issue here if your VPN works wirelessly.
Are you using the router we've sent? Happy to arrange a replacement.
rjenkins123
Hi All,
Thanks for the help.
Just to put what we think is the solution here incase any others find it.
The problem seems to have been related to ipV6 support (or rather, lack of support of ipV6 at PlusNet). The fix my IT department came up with was:
  • Settings -> Network & Internet -> Change Adapter Options
  • Right click on Ethernet Adapter (Intel(R) Ethernet Connection (4) I219-LM), select Properties (admin account required)
  • On "Networking" tab, untick the checkbox next to "Internet Protocol Version 6"
This, touch wood, seems to have fixed it
Richard
Fixes: 1,600
Ah I see, thanks for the heads up Richard!
No problem, let us know if there's anything else you'd need help with.
