Hub1 ppp3 packet loss
Neil63
I am getting this with my hub1, I have turned off the firewall in the router and reset.
Please advise!
21:03:22, 02 Aug. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.7.68.133-​>216.58.213.110 on ppp3)
21:03:19, 02 Aug. BLOCKED 1 more packets (because of ICMP replay)
21:03:19, 02 Aug. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.7.68.133-​>216.58.213.110 on ppp3)
21:03:16, 02 Aug. BLOCKED 1 more packets (because of ICMP replay)
21:03:16, 02 Aug. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.7.68.133-​>216.58.213.110 on ppp3)
21:03:09, 02 Aug. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.7.68.133-​>74.125.136.95 on ppp3)
21:03:08, 02 Aug. BLOCKED 3 more packets (because of ICMP replay)
21:03:06, 02 Aug. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.7.68.133-​>74.125.136.95 on ppp3)
21:02:54, 02 Aug. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.7.68.133-​>216.58.213.106 on ppp3)
21:02:52, 02 Aug. BLOCKED 2 more packets (because of ICMP replay)
21:02:51, 02 Aug. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 51.7.68.133-​>216.58.213.106 on ppp3)
21:01:14, 02 Aug. ( 3143.720000) Lease for IP 192.168.1.64 renewed by host android-​758b2bdef3f8ddd9 (MAC 08:d8:33:9c:90:00). Lease duration: 1440 min
21:01:14, 02 Aug. ( 3143.720000) Device connected: Hostname: android-​758b2bdef3f8ddd9 IP: 192.168.1.64 MAC: 08:d8:33:9c:90:00 Lease time: 1440 min. Link rate: 52.0
3 REPLIES 3
Chris
Legend
Fixes: 169
Re: Hub1 ppp3 packet loss
Is this causing you any issues? Those logs are just saying your router is rejecting certain packets (ICMP), which aren't supported on  the hub one anyway.
Neil63
Son says internet is lagging on playing games. He has tried testing for packet loss and he gets failed tests back so appears to be causing him issues.
As this packet loss seems to appear on normal internet usage also why do you say they are not supported?
Why are they being blocked?
athruntalan
Neil - several people have reported issues with lag and packet loss in the last few days, including myself.
I would suggest lodging a fault if you haven't already, at http://faults.plus.net. The more who do, the quicker this issue will hopefully be resolved.
