Hub1 keeps disconnecting
Got fibre a few weeks ago, and connection has been rock solid.
Since thunder and lightening storm the other night, the hub1 keeps disconnecting, sometimes after 5 minutes, sometimes after an hour.
Is this a problem with the hub1 or a problem at the exchange / cabinet.
Nothing else has chnaged in the house, and the internet has become unusable.
3 REPLIES 3
Fixes: 391
Re: Hub1 keeps disconnecting
I'm just running a few tests on your line.
[edit]
It certainly is dropping. Based on the info I'm going to send you a new Hub One just to be on the safe side.
 Matthew Wheeler
Thanks, once the new hub1 arrives i will let you know how things go
Hub1 replacement plugged in, but still keep getting disconnected. Anything else i need to check ?
