Hub1 details
- Hub1 details
Hub1 details
06-03-2017 7:31 PM
I'm all up and running on Fibre now with the Hub1. I have looked all over for detailed user manual but to no avail. I have 2 questions that I'm hoping someone has already found the answer to.
1 The WPS button. Is it switched off by default? my old ADSL router I had to turn it off.
2 The booklet that came with it has a guide to the lights on the front including a Broadband and a WiFI light. My router only has a long blue light. Am I missing something? Thanks in advance
Re: Hub1 details
06-03-2017 8:40 PM - edited 06-03-2017 8:59 PM
I would suggest taking a look at the BT Home Hub 5 A which is the same as Plusnet Hub1 but rebranded.
The lights and their meaning when the blue changes will also be the same
see
http://bt.custhelp.com/app/answers/detail/a_id/10477/~/user-guides-and-manuals-for-bt-hubs
also see
https://www.plus.net/help/broadband/router-user-guides/#article-content
to gain access to the router type 192.168.1.254 into your browser
and see
https://www.youtube.com/watch?v=b8CDfkR4wZU
Go to advance settings to see what the WPS settings are on.
Re: Hub1 details
06-03-2017 8:49 PM
Thank you. Will take a look
Re: Hub1 details
06-03-2017 8:56 PM
They appear to be the same as the booklet I received with the router but thanks anyway. I may have to contact plusnet direct
Re: Hub1 details
06-03-2017 9:01 PM - edited 06-03-2017 9:10 PM
see for possible further info
https://www.broadbandchoices.co.uk/guides/hardware/plusnet-hub-one
and the video shows how to gain access to the router to check the WPS settings.
Re: Hub1 details
06-03-2017 9:37 PM
There are some useful bits over on the Help site.
You only need to press the WPS button if you want use it to connect a device to the router.
Re: Hub1 details
07-03-2017 6:30 PM
Thanks @Mustrum . My previous router had it set on all the time unless you turned it off which was my reason for asking as will probably never use it. I will take another look on the help section
