Hub one reboots after powerline adapter was added
Marco001
I added a Devolo powerline adapter to my network. In the admin i do see both the adapter and my pc as connected. The moment i request a URL the Hub One is re-booting. Once done, the requested page is shown. But every next request makes it re-boot again.
I checked all the options in the admin, but i have no clue what causes the re-boot or how i can find out more.
3 REPLIES 3
Fixes: 44
Re: Hub one reboots after powerline adapter was added
Does it do the same when you remove the powerline?
Marco001
Nope, once i remove the adapter completely everything is back to normal.
It does seem that even when i return to Hub One wifi and the adapter is still on the network the reboot happens. And that only when i completely remove the adapter, the behaviour is back to normal. But i did test that only once, so not sure if that is really consistent behaviour.
notmyname
Could be that the power line adaptor is using the same IP as the hub one (192.168.1.254). Try changing the gateway address in the power line adaptor if possible.
