turn on suggestions
Hub one makes werid noise and speed dropped dramatically
- Hub one makes werid noise and speed dropped dramat...
26-11-2016 12:27 PM
Received my hub one a few weeks ago and at first it was great, I received the speed I was guaranteed, around 68mb.
then a week ago the speed has dropped down to 10-20mb and the router is making a high pitch noise.
Any ideas? Surely this isn't normal.
Re: Hub one makes werid noise and speed dropped dramatically
27-11-2016 3:56 PM
If the weird noise occurs when the router is in use it's probably the 5GHZ channel it has a tendency to make this noise.
James
28-11-2016 10:51 AM
If you can raise this here we can get this looked into.
Matthew Wheeler Plusnet Help Team |
