Hub light going orange & resetting every 5-10 mins
- Re: Hub light going orange & resetting every 5-10 ...
06-10-2016 1:15 PM
I've had Fibre for about 5-6 months now. A week ago the hub started cutting out every 5-10 mins. We just lose the connection for around 15-30 seconds and during that period of time the light goes orange. It then goes blue again and starts working. It seemed to be fine for about 24 hours then started dropping again. I'm assured this is not a fault in my area (North Yorkshire).
It's obviously impossible to use when it's like this. I've logged a fault and was sent a new hub in case that was the issue - it did not help.
Can anyone suggest a cause for this and a possible solution?
Message 1 of 4
(745 Views)
3 REPLIES 3
Re: Hub light going orange & resetting every 5-10 mins
06-10-2016 1:21 PM
Message 2 of 4
(737 Views)
06-10-2016 1:34 PM
Thanks.
Message 3 of 4
(729 Views)
10-10-2016 2:17 PM
I've just quickly checked your account and see that the fault got closed off today so I'm assuming the fault is fixed now. Drop us a reply back here if not please and I'll follow things up for you.
Message 4 of 4
(659 Views)
