Hub Zero 2704n not fit for purpose
- Hub Zero 2704n not fit for purpose
- « Previous
- 1
- 2
- Next »
Re: Hub Zero 2704n not fit for purpose
16-04-2015 7:03 PM
You can enable WAN ping by downloading cleartext config from 192.168.1.254/dumpcfgdynamic.cmd, editing it, adding lines, and then uploading back to the router. More info here.
Darsh
Darsh
Message 16 of 18
(291 Views)
21-04-2015 6:48 PM
Any word on this yet Plusnet FIRMWARE ?
Tried this earlier twice with stock PLUSNET firmware..... plaintext won't re-upload.....
ERROR.................
Are you guys just pushing the adsl side ?
Any word yet Plusnet or do I gotta hack the damn thing up if it ain't a wind up that is!
cus nothing I try works from that thread on the STOCK firmware!!!!!!!!!!
Quote from: Darsh You can enable WAN ping by downloading cleartext config from 192.168.1.254/dumpcfgdynamic.cmd, editing it, adding lines, and then uploading back to the router. More info here.
Darsh
Message 17 of 18
(291 Views)
21-04-2015 9:03 PM
Quote from: 11110_110 plaintext won't re-upload.....
You just need to remove the space before <xml> in the first line, and remove couple of last lines with the stats after the </DslCpeConfig> tag. Then it will be accepted.
Darsh
Message 18 of 18
(291 Views)
- « Previous
- 1
- 2
- Next »
