Hub One
scottymc
Hub One
Hi guys
I'm upgrading from adsl to fibre on the 2nd , My Hub One has come today do I plug it in now or will the engineer do it all on Wednesday ?
Will it work with my current plusnet adsl or is it a fibre only modem/router
Thank for any advice
23 REPLIES 23
Den1
Re: Hub One
Best to wait till you are upgraded on the 2nd  Wink  although it should be plug and play.
Fixes: 1,483
Re: Hub One
It's both adsl and fibre
Anotherone
Champion
Fixes: 21
Re: Hub One
I would configure it off-line if you want to change any settings (those that your can that is) and put in your username and password instead of the tr069 entries. I would then put it on-line tomorrow in daylight hours a good hour after sunrise and a good hour before sunset as you are on a longer ADSL connection. Your ADSL should work fine and when you are connected to Fibre, it all ought to change over automatically when the work at the Cab is done - famous last words Wink
rosmith52
Re: Hub One
I've installed a Plusnet Hub One today worked straight out of the box.
Just one silly question on the front of the hub under the Status light there's a clear plastic panel with a protective tear off selophane strip over it, what is it for?
Anotherone
Champion
Fixes: 21
Re: Hub One
To protect the clear plastic panel Huh Wink
Welocme to the forum btw.
Now I guess you really mean what's the clear plastic panel for? I can only guess there might be other warning LEDs similar to BT's HomeHub. Try turning off your wireless for example and see if anything else lights up.
Strat
Fixes: 565
Re: Hub One
There are broadband and wifi indicators in that area which are normally off if the relevant service is ok.
Apart from the main status light there are no other reassuring indicators normally visible.
Page 14 of the booklet should explain their usage.
Anotherone
Champion
Fixes: 21
Re: Hub One
Is the booklet on-line anywhere Dick? I couldn't find anything useful when I looked.
Strat
Fixes: 565
Re: Hub One
Sorry, I don't know if it's available online.
Anotherone
Champion
Fixes: 21
Re: Hub One
Typical Plusnet lack of thought and planning of help pages these days Roll_eyes
Strat
Fixes: 565
Re: Hub One
Doesn't look as though there is a video yet for the Hub One https://www.youtube.com/playlist?list=PLZx9FPn3_-IUjbbUJ_9Q2XeXb42z9oTve
Edit: Although I could be wrong if I looked a little deeper Embarrassed
Kimberlin
scottymc
Re: Hub One
Well I set it this morning all went to plan running adsl ..... Now roll on change over day on the 2nd, hopefully the fibre install runs as smoothly
Is there an advanced stats page on this router
All I can find is sync up/down and that's it  Roll_eyes
Anotherone
Champion
Fixes: 21
Re: Hub One
Go to the >Troubleshooting >Helpdesk page Scott. If you copy and paste it into a post, don't forget to redact things like serial number, mac address, usename & SSIDs
As far as the videos go, both (the 3rd is a duplicate) are on the Support Pages as well as the Youtube channel. They are nothing more than the "Dummies Guides". The first covering what's in the box and how to plug it all in, then connect either via WiFi or Ethernet. It has the usual plug it unto the Master socket to get the best Fibre speeds comment, which is actually BS if you have extension wiring AND it's all up to the right standard. BUT there is no mention of extension wiring and how it will seriously affect your speeds if it's NOT up to standard - well done Plusnet Roll_eyes   Right at the end of the video there's mention of a Troubleshooter video and a brief picture of the broadband  "b" light flashing orange in the "plastic panel area" - well done again Plusnet, easy to watch a video if your BB isn't connecting Roll_eyes
The second is all about logging into it and change wireless settings etc and resetting it all. Brilliant.
scottymc
Re: Hub One
Thanks anotherone
Firmware version: Software version 4.7.5.1.83.8.217 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 05:55:39
6. Data rate: 1055 / 4272
7. Maximum data rate: 1068 / 4300
8. Noise margin: 6.1 / 8.7
9. Line attenuation: 27.3 / 47.0
10. Signal attenuation: 27.4 / 46.1
11. Data sent/received: 272.8 MB / 839.5 MB
Lets see how this improves after wednesday
