Hub One
- Re: Hub One
Hub One
28-11-2015 1:00 PM
I'm upgrading from adsl to fibre on the 2nd , My Hub One has come today do I plug it in now or will the engineer do it all on Wednesday ?
Will it work with my current plusnet adsl or is it a fibre only modem/router
Thank for any advice
Re: Hub One
28-11-2015 1:27 PM
Re: Hub One
28-11-2015 1:44 PM
Re: Hub One
28-11-2015 5:30 PM
Re: Hub One
29-11-2015 10:14 AM
Just one silly question on the front of the hub under the Status light there's a clear plastic panel with a protective tear off selophane strip over it, what is it for?
Re: Hub One
29-11-2015 10:52 AM
Welocme to the forum btw.
Now I guess you really mean what's the clear plastic panel for? I can only guess there might be other warning LEDs similar to BT's HomeHub. Try turning off your wireless for example and see if anything else lights up.
Re: Hub One
29-11-2015 11:03 AM
Apart from the main status light there are no other reassuring indicators normally visible.
Page 14 of the booklet should explain their usage.
Re: Hub One
29-11-2015 11:18 AM
Re: Hub One
29-11-2015 11:25 AM
Re: Hub One
29-11-2015 11:30 AM
Re: Hub One
29-11-2015 11:38 AM
Edit: Although I could be wrong if I looked a little deeper
Re: Hub One
29-11-2015 12:20 PM
Re: Hub One
29-11-2015 3:21 PM
Is there an advanced stats page on this router
All I can find is sync up/down and that's it
Re: Hub One
29-11-2015 3:55 PM
As far as the videos go, both (the 3rd is a duplicate) are on the Support Pages as well as the Youtube channel. They are nothing more than the "Dummies Guides". The first covering what's in the box and how to plug it all in, then connect either via WiFi or Ethernet. It has the usual plug it unto the Master socket to get the best Fibre speeds comment, which is actually BS if you have extension wiring AND it's all up to the right standard. BUT there is no mention of extension wiring and how it will seriously affect your speeds if it's NOT up to standard - well done Plusnet Right at the end of the video there's mention of a Troubleshooter video and a brief picture of the broadband "b" light flashing orange in the "plastic panel area" - well done again Plusnet, easy to watch a video if your BB isn't connecting
The second is all about logging into it and change wireless settings etc and resetting it all. Brilliant.
Re: Hub One
29-11-2015 4:19 PM
Firmware version: Software version 4.7.5.1.83.8.217 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 05:55:39
6. Data rate: 1055 / 4272
7. Maximum data rate: 1068 / 4300
8. Noise margin: 6.1 / 8.7
9. Line attenuation: 27.3 / 47.0
10. Signal attenuation: 27.4 / 46.1
11. Data sent/received: 272.8 MB / 839.5 MB
Lets see how this improves after wednesday
