Hub One router noise
adamtregaskis
my router makes a 'chirping' noise when the internet is being used. as it sits in the same room i watch tv in, it is quite annoying as it is quite loud.
is it normal for it to make a noise?
Gel
Seasoned Pro
Fixes: 14
adamtregaskis
Re: Hub One router noise
so, that suggest's mine is faulty then?
rongtw
Fixes: 12
there was some time ago a similer occurance with a batch of routers that was singing Sad
https://community.plus.net/t5/Broadband/Noisy-Router-Investigation/m-p/1000507#M220031
Fixes: 20
Different device, different issue
https://community.plus.net/t5/My-Router/Hub-one-makes-high-pitched-noise/td-p/1326576
Apparently it happens when using the 5GHz wireless.
adamtregaskis
still unclear if this means it's 'normal' so i have to live with it or buy a better quality router.
or is it a common fault that requires a replacement router?
