Hub One router - PoE?
johnwnice
Anyone know if the Hub One supplies power over Ethernet?  I can't find any info one way or t'other
3 REPLIES 3
Plusnet Staff
Plusnet Staff
Fixes: 118
Re: Hub One router - PoE?
Not something I'm aware of, but from searching Google it appears not I'm afraid.
Perhaps the community on here will have a more definitive answer.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
VileReynard
Champion
Fixes: 17
You could buy a switch to provide PoE - but they cost a lot more than a normal switch.
Fixes: 45
@johnwnice - I've found these to be worth while.
