Hub One router - PoE?
- Re: Hub One router - PoE?
17-12-2016 6:15 PM
Anyone know if the Hub One supplies power over Ethernet? I can't find any info one way or t'other
Message 1 of 4
(2,250 Views)
3 REPLIES 3
17-12-2016 6:21 PM
Not something I'm aware of, but from searching Google it appears not I'm afraid.
Perhaps the community on here will have a more definitive answer.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Message 2 of 4
(2,241 Views)
17-12-2016 6:29 PM
You could buy a switch to provide PoE - but they cost a lot more than a normal switch.
Message 3 of 4
(2,236 Views)
17-12-2016 6:50 PM
@johnwnice - I've found these to be worth while.
Message 4 of 4
(2,220 Views)
