Hub One incorrect sync rate
goldenfibre
Fixes: 6
Hub One wrong on sync rate on two different seem confusion. BT IP Profile reported 77.34Mb for Hub One is rather odd as it always 77.35Mb on other routers.
Software version was last updated: 12/02/2017. The sync rate at 79903K need to be fixed as it should be 79999K. Maybe software bug.
1.jpgSync at 79.9/20.02.jpgSync at 79903K / 19999K
goldenfibre
Fixes: 6
Re: Hub One incorrect sync rate
Software has now been updated.
Fixes: 20
Surely this is not really a problem, it's just that it connects at a slightly different line rate?
Gladstone
Are you having noticeable speed problems?
