Hub One firmware update
FIXED- Subscribe to RSS Feed
- Re: Hub One firmware update
21-11-2018 5:25 PM
Ah, odd. Sure I upgraded it earlier when I last looked at this thread. Your router should be going down for a reboot now to apply the update
21-11-2018 5:29 PM
Just happened "Software version 4.7.5.1.83.8.259.1.1 Last updated 21/11/18" Thanks
23-12-2018 10:10 AM
I seem to be having the same problem; my software version is 4.7.5.1.83.8.237.2.2
Can you provide me with what I need to perform an update?
Cheers,
Dan
24-12-2018 6:13 PM
Hi @maddogmilner, I've raised a request with the relevant department regarding a firmware update on your router, however could you elaborate on what problems you're experiencing with your connection currently.
Thanks.
27-12-2018 12:37 AM
27-12-2018 9:58 AM
I experience intermittent Wi-Fi connectivity with all devices in the house. It's mostly connected, but we all experience occasional dropouts which seem to be router based.Naturally, I can't begin to cover my bases without knowing the firmware is up to date first.
I also notice an issue with my NAS drive not achieving the full 1Gbit at its port anymore. Again, before I start replacing cables I need to know the firmware is fully up to date.
Cheers,
Dan
31-12-2018 1:09 PM
Hi @Bellhunt, could you confirm what firmware version you're currently on please.
@maddogmilner, I've had confirmation that the firmware update was pushed through to your router a couple of hours ago.
I hope this helps.
09-01-2019 12:06 PM
Can I also have the firmware update, I am stuck on 237.2.2 and suffering the same issues of wifi drop out as others seem to have. My router even seems to dislike the lan port at times until device rebooted or left a while. As if slow to connect.
09-01-2019 1:44 PM
Hi @kcvfr400
My colleague @bobpullen has been prevalent on the community this morning and should be able to assist with this.
Best wishes
Dave
09-01-2019 6:47 PM
@kcvfr400, I've upgraded your firmware, however worth mentioning that there are no known wi-fi issues affecting the build you're currently on.
09-02-2019 5:47 PM
Hey there, would appreciate a little Firmware bump myself.
Recently moved back to using the hub one after my own wireless router gave up the ghost.
Current Firmware version is 4.7.5.1.83.8.226 Last updated 30/09/16
Wanting to get onto the latest Router firmware before I start debugging some frequent DNS issues i'm having on my WIN10 Laptop, as well as investigating the excessively frequent "Lease Requested" messages in the hub ones logs (coming in every 3-5 seconds)
Cheers
10-02-2019 1:40 PM
Hi @jabraehead,
Thank you for getting in touch. I've passed this on to our product team and have asked them to push out the latest firmware update to your router.
15-02-2019 9:13 AM
Could you please push a firmware update to me please?
15-02-2019 9:24 AM
@jabraehead, yours was done on the 10th.
@stevenstrong, I've just upgraded yours. It will have rebooted to apply the update.
15-02-2019 9:29 AM
Brilliant. A very impressive service
