Hub One Wireless Shocking
- Re: Hub One Wireless Shocking
26-05-2017 5:25 PM - edited 26-05-2017 5:29 PM
Just renewed my contract with plusnet for a further 2 years, got a bit off my monthly amount and sent the Hub One.
Pros: i get 1meg faster download via ethernet now 75 down and near enough 19 up
Con: The wireless is rubbish to non existant for connecting.
I need a solution because this is no good for using around the house with my phone or laptop, the techicolour was miles better for wireless than what i have now. Plusnet you told me when i renewed i would get a much better experience with the Hub One than what i was on previously i'm a little non pleased.
Looks like i have no option to get a recomendation for a much better router than this or go back to the technicolour, any ideas? So far on the 3rd channel change on 11 from 6 & 1 previous, even the customer service agent said yeah the wireless isn't very good.
Thanks Plusnet
26-05-2017 6:54 PM
26-05-2017 9:10 PM
You would be better getting a WiFi app or program like 'inSSIDer' to see what else is transmitting in you area, then changing your routers channels to the least congested.
26-05-2017 10:04 PM - edited 26-05-2017 10:07 PM
Mainly the smartphone around the house wirelessly. if my prervious router was ok with wireless and now i'm using the hub then isn't the hub the issue?
26-05-2017 10:08 PM
No, smartphones receive, the don't transmit wifi, , but you may have neighbours who have stronger WiFi routers transmitting on the same signal as you router, especially if you live in a built up area.
27-05-2017 10:27 AM - edited 27-05-2017 10:28 AM
Changing the channel might well work in some instances but with the Hub One doubtful. It's wireless performance is quite pathetic.
I had wifi problems, poor signal, constant wireless disconncts etc., with mine and carrying out all the recommended "solutions" did absolutely nothing.
After replacing it with a better purchased modem/router all the problems disappeared. The Hub One has been "binned."
27-05-2017 11:40 AM
All wireless devices both transmit and receive - it's a two way connection. There were quite a lot of complaints about the 582n's wireless performance back when it was the router that Plusnet supplied.
The other thing usually suggested is to give the 2.4GHz and 5GHz wireless networks different names.
27-05-2017 11:45 AM - edited 27-05-2017 11:47 AM
Are you using 5Ghz or 2.4Ghz band on the Hub One? Just thinking the Technicolor router only did 2.4Ghz which, although isn't as fast as 5Ghz, reaches further than 5Ghz.
27-05-2017 11:49 AM
You could have the technicolor in another room as a "slave" to the Hub One. I have a Draytek as main router with mains n/w plugs for some devices which I wanted on wired connections.The tecnicolour is connected to draytek via this also. Both routers have same wifi logns but on different channels. DHCP is off on technicolor and has static ip outside of the Draytek DHCP range so all "routing" is done by the Draytek. Works well for me but may not suit everyone.
31-05-2017 12:17 AM - edited 31-05-2017 12:18 AM
