Hub One Modem Only
- Hub One Modem Only
Hub One Modem Only
02-12-2015 5:28 PM
Hi.
Just got my Hub One delivered and am waiting for my line to be activated. In the meantime I have a question. I have moved from Virgin who used a similar device called a super hub. I was never happy with the back end configuration so I bought myself a Netgear Router and put the hub into "Modem Mode" this meant it no longer acted like a router just a modem. Is there a feature on the Hub One which would allow me to do the same?
Thanks.
Fraser.
Thanks.
Fraser.
Message 1 of 2
(1,083 Views)
1 REPLY 1
Re: Hub One Modem Only
02-12-2015 6:06 PM
Not as far as I know, but you can connect your Netgear router if you change the ip address on it, some will even do it for you.
Message 2 of 2
(619 Views)
