Hub One ADSL to Fibre switchover
I am upgrading to fibre, my Hub One is on the way. I hope to set it up on my existing adsl line. When my fibre is activated (22nd Jan) will I need to change anything or will the Hub One connect at the new speed automatically?
2 REPLIES 2
Re: Hub One ADSL to Fibre switchover
My Hub One arrived the morning of switchover so had it running first on adsl - needed initial ethernet connection to get things started.
Lost connection when cabinet changed and router needed restart.
Thanks nadger.
