Huawei 612 Modem
daz1107
Huawei 612 Modem
Ok, I bit the bullet and have one winging it's way to me from evilbay.
Question is, could someone point me to some 'idiot proof' instructions for unlocking and flashing the required firmware please?
I took the decision as my speed is falling and my IP profile continues on it's daily reduction, so lets see what happens!
Cheers guys  Grin
24 REPLIES 24
robbiecollie
Re: Huawei 612 Modem
hi copy this link and down load the firmware also the instructions are within the firmware
http://www.kitz.co.uk/routers/hg612unlock.htm#hg612_hacking
NoZephy
daz1107
Brilliant!! - Thanks to you both.
It should be delivered on Wednesday, so if I get stuck, as Arnie said....'I'll be back!!'  Tongue
NoZephy
Haha, it shouldn't be too hard. Let us know how you get on.
Also, I'm just gonna stick this in here because I can but if you ever get fed up of having to bridge BT's modem's and a router together you should look at the Billion 8800NL.
Using one myself and it's fantastic for Fibre, costs around £60 I believe and also does ADSL2+ if you ever had to fall back to that service for whatever reason Smiley
daz1107
Heeeeeelllllllllllpppppppppppp!!!!!!
I just cannot connect to the modems interface page when typing the 192.168.....number - nothing happens; it just says cannot connect.
Do I need to be plugged into the telephone wire or can I do it as a standalone unit without being connected.
I'm holding the reset button, putting the power lead in, but nothing.....
Any advice chaps before I throw it through the window???  Angry Angry
Fixes: 10
I unlocked mine using a laptop connected direct to the modem with the modem connected to nothing else.
To check you have set it up correctly you have to remove the LAN2 not in use label and plug in to there. On the PC etc. you are using to connect you must set it's IP to 192.168.1.100. You should then be able to access modem via http://192.168.1.1
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
NoZephy
Posting to back Jelv's comment, you should use LAN2 to access the modem.
daz1107
I was using LAN2, but couldn't get anything - errr, stupid question time; how do I set the IP on my windows 8 laptop??? Embarrassed
I'll have another go tonight when I get home from work.
St3
Aspiring Champion
Fixes: 5
locked or unlocked whats the difference ? Bt role updates out to it dont they ?
gkf9
St3
People unlock them so they can see their line stats etc etc, and get a detailed GUI, if they are having problems.
Fixes: 4
If unlocked, I believe it's possible to switch off the service that picks up updates.
Call me 'w23'
goldenfibre
Fixes: 7
I agree get a Billion 8800NL for less hassle!
Stoker
Quote from: daz1107
...how do I set the IP on my windows 8 laptop??? Embarrassed
- Control Panel / Network and Internet / Network and Sharing Center / Change Adapter Settings (on left)
- Right-click the adapter you're using / Properties
- Double-click Internet Protocol Version 4
- Click "Use the following IP address"
- Put 192.168.1.100 in the address box.  Subnet mask will populate and others don't matter.
Change back to "Obtain IP address automatically" when you're finished.
St3
Aspiring Champion
Fixes: 5
Quote from: gkf9
St3
ok cheers bud
