Huawe Stats HG635
robbiecollie
Huawe Stats HG635
Huawe Stats  HG635 Ive just obtained one that is unlocked can access the basic stats but cant find line speeds etc is another program needed
Fixes: 6
Re: Huawe Stats HG635
You'll find the stats in two places.
1) over on the right under maintenance broadband.
2) on the left -- cant remember the actual place, sorry don't have a HG635 handy. Edit under "Home"
Ignore the reported result for "interleaving" it's wrong.
PS
They are not locked in the first place.
robbiecollie
still cant find line stats
Fixes: 6
You can see the stats from my hg635 at the bottom of this page:
http://npr.me.uk/hg635.html
Is that what you're looking for?
If you want more detailed stats then you need to install a custom conf file and use telnet, unfortunately that method has security issues. -- something I would not recommend.
If you're using it in router only mode, connected to a BT modem, then there's no stats to be had.
