How to page down webmail
FIXED- Subscribe to RSS Feed
- Re: How to page down webmail
03-03-2019 9:49 AM
Please help - I have gone over my mailbox size limit and have to delete emails. I want to target unwanted emails but I can't find how to page up or down my email list in webmail (I'm on IMAP and can't permanently delete from my local server). The scroll wheel, up/down keys and page up/down keys all just move approximately one and a half pages of emails, obviously not enough for me to find the ones out of the total of the nearly three thousand that I want to delete.
All help most gratefully received.
Fixed! Go to the fix.
03-03-2019 1:35 PM
Hi @Weystoner1,
I don't think you can scroll in the way that you're describing - however, the headers/arrows at the top of the email page will allow you to "sort" by size/date etc if this helps?
If you're running out of space, I would recommend sorting via largest email size first and targeting the emails that are using the most space.
Best wishes
Dave
03-03-2019 2:27 PM
Click on settings, then in Section select Mailbox view. Just change the number in “rows per page” to whatever you think you need (try to keep it below 200 as it might slow down the loading time).
To get to other pages click the “play” icon next to the message total, which appears bottom right of the window.
03-03-2019 2:59 PM
Thanks Randall, but I've already sorted by size and deleted the largest emails. I now want to target emails from specific sources, so I need to sort alphabetically; obviously Facebook (for instance) is not going to be on the top page.
03-03-2019 3:09 PM
Thanks for the tip re page size RPM. However, I can't find a 'play' icon bottom right or anywhere else.
Hang on, just found it: the icon doesn't show up, but I passed the mouse over the area to the right of the total and the cursor arrow changed to a pointing finger. No idea why the icon is hidden, but you obviously have hidden talents (arf arf)! Many thanks.
03-03-2019 10:47 PM
04-03-2019 9:42 AM
It's probably the browser: I'm still using Explorer for my PlusNet login (don't ask). I'll change today to Edge and see what happens.
04-03-2019 11:35 AM
Arrows show up on Edge - many thanks for your help.
