How to get a replacement Openreach socket faceplate?
Gwyd
Hello all,
I moved house and brought my plusnet service with me. Sadly, the FTTC socket already in the house wasn't working, and after some support from plusnet, I'm now connected through an additional filter to the master socket.
I would like to get the socket working, as I have a rather powerful router I'd like to use that would have connected through the socket, but now can't use - defaulting back to the plusnet supplied router.
How would I go about getting a replacement faceplate? Would this be through plusnet, or is it something I'd have to contact openreach for?
Many thanks for all your help in advance,
Gwydion
10 REPLIES 10
Fixes: 102
Re: How to get a replacement Openreach socket faceplate?
Yes, we can arrange this. Just so you know there would likely be a charge of £65.
 Adam Walker
Gwyd
Thanks for the prompt reply!
Blimey - shouldn't a new house move come with working socket? Seems a bit harsh to have to pay for it if it never worked.
bill888
All Star
Fixes: 26
fwiw, it is unclear why you can't use your own router if you successfully got the Plusnet router working.
If your preferred router has a built-in VDSL modem, can't you just unplug the phone/broadband cable from the back of the Plusnet router and insert it into your router?
If you think you just need a replacement Openreach VDSL face plate, you can buy them from eBay. Search for 'Openreach MK3' to see if it is what you require.  Cost less than 9 quid.
(There is also a newer style MK4 face plate if the existing master socket was installed in the last 12 months.  MK3 and MK4 are not interchangeable)
198kHz
Aspiring Hero
Fixes: 15
I'm thinking the same as bill888 - what's so special about this "rather powerful" router?
To err is human, but to really foul things up requires a forum upgrade.
Fixes: 731
Not always. If we arrange a new line installation and an engineer visits your property they may install a new socket but that's not guaranteed as they'd just do that for quality purposes.
Fixes: 7
When I moved into my property and we got the line connected, they changed the front of the socket.
This was just a standard master socket (so not ADSL) and charged us £40 at the time (2011).
We knew the people who lived there before, so didn't notice any problem with the old one, as we used to speak to them on their landline.
No idea of the reason why, whether it was legit, or to make money on a new one. Oh well.
Gwyd
Thanks Bill,
no, my router doesn't have a built in modem: it's an Asus RTAC68U with OpenWRT on it in case you were wondering. I just don't fancy tacking on a modem in front of it if I can avoid it.
Brilliant knowledge on the faceplates - I'll have a look and order one myself. It's definitely over a year old - so Mk3 it is.
Many thanks.
edit: Just had a thought - do I need a fibre modem anyway? I am very likely an idiot Wink
brookheather
You can't plug an RT-AC68U router into the phone line - it is just a router and doesn't have a modem - you still need a modem to get internet.  You can change the Plusnet router for a VDSL modem (e.g. Vigor 130) or change the RT-AC68U router for a new modem/router with a VDSL modem included.
You could use your router as a wireless access point and disable wifi on the Plusnet router - just change the Asus router to Access Point mode.
FTTP + pfSense + Asus RT-AC67U AiMesh
bledd
Yup
You'll either need a Draytek Vigor 130 or an Openreach HG612 from ebay.  Your router has no modem in it.
Fixes: 7
Yes, as said, I think basically you need to get a separate modem if you wish to carry on using your existing router, or get another which has a modem built in.
Depends on whether having two devices will bother you (putting them somewhere, enough plug sockets etc.) you like your current router and can live with it, or if you would prefer to have one device then you would have to get something else with a modem built in.
