How to disable IPv6 in plusnet router?
rkhost
Any ideas?
Plusnet Staff
Plusnet Staff
Re: How to disable IPv6 in plusnet router?
By default, this is switched off.
 Tony
 Plusnet Support
Fixes: 4
If you mean the DHCPv6 server on the 2704n, then have a mooch here... 192.168.1.254/expert_user.html    /Advanced Setup/Lan/IPv6 Autoconfig
