How to change router from 2.4 Ghts to 5.0 Ghtz
- How to change router from 2.4 Ghts to 5.0 Ghtz
25-01-2019 10:55 AM
I have a Hub One which is set to 2.4 Ghtz how do I change it to 5.0 Ghtz
Re: How to change router from 2.4 Ghts to 5.0 Ghtz
25-01-2019 11:04 AM - edited 25-01-2019 11:14 AM
If it's in its default state it's transmitting on both frequencies in synchronism and your device has decided to use the 2.4 GHz channel. What you need to do is separate the bands then select the 5 GHz band on your device list of available wifi networks. The password will be the same as for 2.4 GHz. See https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840 for separating the bands.
25-01-2019 11:16 AM
Generally this band is much more populated/busy than 5ghz, at least currently!
25-01-2019 11:44 AM - edited 25-01-2019 11:46 AM
To avoid confusion whilst I agree with you the OP states that this topic is about a Hub One, which as we both know is dual band.
25-01-2019 12:15 PM
I have just spoken to Asus who's laptop I have and they say it will receive 5.0GHz signals
25-01-2019 12:30 PM
See your other post. Removing the syncronisation in the router should be your first move. The Asus can receive both frequencies and could well be getting confused by having both coming in with the same SSID and password.
