How to access modem (openreach) logs and admin?
dcdc
Am seeing constantly dropped connections from the router (Wifi or network not sure). Have changed routers (now netgear) and still same thing.
I can see the logs in the netgear router manually (let me know if anyone knows a way to curl the logs, can send via email) but I would like to see if anything is reported on the modem.
Isn't there some modem login? Have tried numerous usual LAN IP already but no luck.
4 REPLIES 4
Fixes: 457
Re: How to access modem (openreach) logs and admin?
From your description I assume that you have a seperate modem. This should either be an ECI or Huawei device. You can log into these and get basic data (192.168.1.1)  but they are pretty well locked down by BT. There's nothing else that you can do with the ECI device without modifying the electronics but the Huawei modems can be easily unlocked. See here.  https://kitz.co.uk/routers/hg612hacking.htm you can then run a logging programme.
dcdc
Yeah, it's an ECI modem. Sneaky. Was trying to find out if BT was running there FON stuff on plusnet devices as well ... maybe someone knows who hits this thread.
Fixes: 457
Sorry, no free FON service with a Plusnet account. You can always buy a HG612 model 3B for very little money on Ebay and unlock it.
dcdc
Not looking for "free" ... was *worried* BT was riding my network.
