How long until bRAS update? (new FTTC)
LordFox
I got changed over earlier today. It seemed to go very smoothly - off for maybe ten minutes then the modem reconnected. Had to manually reconnect my PPPoE session on the router. But thumbs up so far Cool
However I'm still getting exactly the same download speed as I did on ADSL, although the upload has gone to 18Mbps Thumbs Up . Tested a few times on several testers including BT's.
How long do I have to wait for the bRAS profile to be updated? I guess that is all that's needed. I'm wary of dropping my line and reconnecting at random because I don't want to upset the DLM. BT speed test says "an error occurred while trying to retrieve additional details" and can't give me the profile.
Anyway, so far, so (very!) good folks. This is what my modem now tells me:
       VDSL Port Details       Upstream         Downstream
               Line Rate:     20.063 Mbps       80.103 Mbps
    Actual Net Data Rate:     19.999 Mbps       79.987 Mbps
          Trellis Coding:         ON                ON
              SNR Margin:       15.0 dB            9.8 dB
            Actual Delay:          0 ms              0 ms
          Transmit Power:        6.6 dBm          13.0 dBm
           Receive Power:       -9.4 dBm          -1.8 dBm
              Actual INP:        0.0 symbols       0.0 symbols
       Total Attenuation:       16.0 dB           14.7 dB
Attainable Net Data Rate:     34.521 Mbps       93.612 Mbps
Fixes: 205
Re: How long until bRAS update? (new FTTC)
Can you try a disconnect/reconnect?
That should do the trick.
 Matthew Wheeler
LordFox
Thanks, yep, that got it. Now getting about 74/16.
Good job PN (and, as much as I hate to say it, BT) Thumbs Up
gromit69
I love this forum. Just as I'm thinking of asking a question, someone else asks it Smiley
However, I'm still stuck on my old ADSL down speed after a router reboot. Booo Sad
(however, I'm getting a solid 15 down/15 up!)
Fixes: 205
@gromit69 If you disconnect then reconnect it should be sorted.
 Matthew Wheeler
gromit69
You're on fire @MatthewWheeler - thank you!
60 down 16 up (80/20 connection speed)
Now, if you excuse me, I have the internet to download...
