How long to become stable ??
- How long to become stable ??
14-07-2017 4:31 PM
Took the plunge, upgraded to fibre, and am now wondering how long before I get near the speed I should .
I'v looked at some other posts and done the check via BT :
Down Up
I should have :- VDSL A 80 74.8 20 20
VDSL B 80 59.1 20 17.8
Speed check shows :
Ping | Download | Upload |
100 ms | 11.46 Mb/s | 1.57 Mb/s |
Two days ago, on ADSL, I had 7.92Mb/s down and .93 Mb/s up
Just as well I didn't take the TV option ( yet ) as not reaching the minimum 15 Mb/s download speed.
I'm 1km from the exchange and roughly 200 mtrs from the " green box " using a new OpenReach model 5 thingy.
Regards ..
Re: How long to become stable ??
14-07-2017 4:34 PM
The stabilization period should not apply to FTTC circuits.
14-07-2017 4:36 PM
So that means what I'm getting is what I'll get ?
14-07-2017 4:39 PM
If these your quoted estimates...
Then either your Connection profile is incorrect, or you have a fault. I'm sure the kind folk over at Plusnet would be happy to check this for you
14-07-2017 5:23 PM - edited 14-07-2017 5:25 PM
have you checked the connection speed reported by the router
Note you are probably on standard fibre with maximum connection speeds of 40/2
14-07-2017 6:37 PM
14-07-2017 7:38 PM
OK, finished the evening meal and checked the line :
101 ms | 39.86 Mb/s | 2.10 Mb/s |
Thanks all; so next weeks' pension will go on TV !
Regards..
17-07-2017 9:05 AM
