How long to become stable ??
C1Rider
Took the plunge, upgraded to fibre, and am now wondering how long before I get near the speed I should .
I'v looked at some other posts and done the check via BT :
                                         Down        Up
I should have :- VDSL A 80  74.8   20  20
                          VDSL B 80  59.1  20  17.8
Speed check shows :
Ping Download Upload
100 ms 11.46 Mb/s 1.57 Mb/s
Two days ago, on ADSL, I had 7.92Mb/s down and .93 Mb/s up
Just as well I didn't take the TV option ( yet ) as not reaching the minimum 15 Mb/s download speed.
I'm 1km from the exchange and roughly 200 mtrs from the " green box " using a new OpenReach model 5 thingy.
Regards ..
7 REPLIES 7
notmyname
Re: How long to become stable ??
The stabilization period should not apply to FTTC circuits.
C1Rider
So that means what I'm getting is what I'll get ?Huh
notmyname
If these your quoted estimates...
Then either your Connection profile is incorrect, or you have a fault.  I'm sure the kind folk over at Plusnet would be happy to check this for you Smiley
Oldjim
Resting Legend
Fixes: 63
have you checked the connection speed reported by the router
Note you are probably on standard fibre with maximum connection speeds of 40/2
MatthewWheeler
Fixes: 480
There's a stuck profile which will have caused this.
Can you try retesting it now?
 Matthew Wheeler
C1Rider
OK, finished the evening meal and checked the line :
101 ms 39.86 Mb/s 2.10 Mb/s
Thanks all; so next weeks' pension will go on TV !
Regards..
MatthewWheeler
Fixes: 480
Glad to see it's improved!
 Matthew Wheeler
