How long should it take to upgrade
watsonm
How long should it take to upgrade from unlimited fibre to unlimited fibre extra.   I would have thought it was "just" a profile change but obviously not.   Ordered 31st Oct and still on lower speed
Plusnet Fibre 80/20 Netgear R7000 and Netgear DM200
Plusnet customer since 2002
Plusnet Mobile since 2017
9 REPLIES 9
pjmarsh
Fixes: 20
Re: How long should it take to upgrade
Hi
Those types of upgrades usually tale place on your next billing date.
Phil
Browni
Aspiring Hero
Fixes: 60
It happened overnight for me when I upgraded through the Member Centre.
watsonm
Thanks for that Phil ,  however on the phone call I was told up to 48hours after asking a direct question.
pjmarsh
Fixes: 20
It's possible that my info is out of date, or there might have been a misunderstanding.
What used to happen (but may have changed, so sorry if it has), the product change on the Plusnet side would go through on the next billing date.  If that also included a change to how your line is provisioned then the order for that would also be placed.
If you are going from Unlimited Fibre (40/2 or 52/10) to Unlimited Extra (80/20) then that would need an order to BT which are usually next day (or next working day, I can't quite remember).  If it is from the Unlimited Fibre (40/20, if there is still anyone provisioned on that) then it would just be a change at the Plusnet side.
Phil
watsonm
Phil,  thanks again...
Just impatient as usual
(not helped by Crashplan taking forever to backup on 2Mb/s upload)
adamwalker
Fixes: 221
The requisite order to change the speeds on BTW systems hadn't been placed for some reason so sorry about that.
I've placed the order now so your speeds should increase tomorrow.
 Adam Walker
watsonm
Adam , thanks for the prompt update...   Mike
adamwalker
Fixes: 221
No worries Mike, glad to be of help.
 Adam Walker
watsonm
Upgrade now active.  Thanks
