How long should it take to upgrade
- Re: How long should it take to upgrade
03-11-2016 12:17 PM
How long should it take to upgrade from unlimited fibre to unlimited fibre extra. I would have thought it was "just" a profile change but obviously not. Ordered 31st Oct and still on lower speed
Plusnet customer since 2002
Plusnet Mobile since 2017
03-11-2016 12:35 PM
Hi
Those types of upgrades usually tale place on your next billing date.
Phil
03-11-2016 12:39 PM
It happened overnight for me when I upgraded through the Member Centre.
03-11-2016 12:40 PM - edited 03-11-2016 12:41 PM
Thanks for that Phil , however on the phone call I was told up to 48hours after asking a direct question.
03-11-2016 12:46 PM
It's possible that my info is out of date, or there might have been a misunderstanding.
What used to happen (but may have changed, so sorry if it has), the product change on the Plusnet side would go through on the next billing date. If that also included a change to how your line is provisioned then the order for that would also be placed.
If you are going from Unlimited Fibre (40/2 or 52/10) to Unlimited Extra (80/20) then that would need an order to BT which are usually next day (or next working day, I can't quite remember). If it is from the Unlimited Fibre (40/20, if there is still anyone provisioned on that) then it would just be a change at the Plusnet side.
Phil
03-11-2016 12:52 PM
Phil, thanks again...
Just impatient as usual
(not helped by Crashplan taking forever to backup on 2Mb/s upload)
03-11-2016 12:53 PM
03-11-2016 12:55 PM - edited 03-11-2016 12:55 PM
Adam , thanks for the prompt update... Mike
03-11-2016 3:06 PM
04-11-2016 3:17 PM - edited 04-11-2016 3:18 PM
Upgrade now active. Thanks
