How long for speed increase?
- Re: How long for speed increase?
23-10-2014 10:17 AM
Just had fibre installed. Your website says
Estimated line speed:32Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-10-08 11:22:22
Current line speed:40 Mb
I am getting 14. so will this go up? Others have had full speed right off the start
Cheers
23-10-2014 10:25 AM
Can you run this speed test http://www.thinkbroadband.com/speedtest.html and post the results?
23-10-2014 10:31 AM
Better than the 6mbps we had but I was hoping for more as we have gone from 50P a month to £20
http://www.thinkbroadband.com/speedtest/results.html?id=141406021017616242753
23-10-2014 10:51 AM
After the initial test you should get a button on screen offering 'Further Diagnostics', please select this and, once completed, you should see (amongst other things): "Additional Information: IP Profile for your line is...", please advise the figure it gives.
23-10-2014 11:42 AM
23-10-2014 1:19 PM
23-10-2014 2:00 PM
Got another router coming because this one is not right.
23-10-2014 3:05 PM
23-10-2014 3:45 PM
That's my dads login in case you wonder why I am responding
I believe the Router had a funny turn, After 2 hard resets it's back up and stable but the line profile has gone back to the 5.8mbps they had before the profile was changed this morning to 40mbps ready for the FTTC to fo live - It ran for 15 mins and then went dead.
By another router he meant I have put my hardware on there which I don't use (so same router) and it's working fine - tr69 picked it up and it's been online since.
So I don't think it's a fault, and although they are currently on the same speed they always where they would like it back to 40mbps as soon as possible - although even then it was only reaching 14mbps but that's another matter.
23-10-2014 3:57 PM
We honestly didn't know it was you responding but cheers for clearing that up.
I can see the speed profile looks to be correct on your account but if this is still an issue I'd disconnect and reconnect by logging into the router:
http://www.plus.net/home-broadband/router-reconnect/
23-10-2014 4:03 PM
No it was my dad but it was me in the last post I was there though at the time it was being written.
The speed profile on my dads account is the one that we query. So you are saying it's now 40 and not 5.8 but needs a reboot to update on the portal?
I've called and it's being power cycled as I type this (Just TC not BTO)
Cheers
23-10-2014 4:27 PM
23-10-2014 4:28 PM
I've just changed the WP profile for you (after your last post). Can you do me a favour and reconnect, but don't switch the router off. I'm a bit concerned with the lost carrier drops.
Tony
23-10-2014 4:35 PM
23-10-2014 5:10 PM
Right they have done that - they are now back to what they got before the problem kicked off - 15mbps down and 6mbps up. I've told them to wait for a few days to see if this increases. It should do I hope.
The LCD's were probably me earlier when I was getting that horrible " disconnected by user" that we fight all the time.
