How long for DLM to increase IP Profile?
bigwest
My down connection speed has been limited to 34999kbps for a few months now. I'm on the unlimited fibre 40/10 package and to start with was connected at the full 40Mb.
I was originally using my Netgear D7000v2 in modem+router modem and had resyncs every few days. I believe this is what caused me to go on a banded profile in the first place.
I've since started using a Huawei HG612 as the modem and monitoring the line status using DSLstats.
I've now been connected for 34 days without any resyncs and very low ES/hour from what I can see. Does anyone know how long it should take for DLM to increase my IP Profile back closer to 40Mb?
Previously when I've been on 80/20 packages I've managed to get 55Mb syncs so 40Mb should be easily achievable for my line.
2 REPLIES 2
Terranova667
Fixes: 5
Re: How long for DLM to increase IP Profile?
If the line is banded it won't increase on its own DLM can't remove it, Plusnet would have to make a request to BTW for a reset.
bigwest
Perhaps I've got my terminology wrong. Is it not the case that DLM would have lowered my IP Profile and there will be a barrier threshold on the line that it will need to get past before profile speed increases?
