How long does it take to activate my router
lewiss11
The engineer came around and installed my router and said everything is all good and it could take anywhere from 10 minutes to and hour or right up to midnight, about 2 hours after he installed it the power light went blue which I thought was a sign it was connected but a few minutes later it went back off is this normal?
Tags (2)
2 REPLIES 2
Fixes: 848
Re: How long does it take to activate my router
Thanks for your post @lewiss11 I'm sorry to see there's a delay with your broadband order.
From reading the order notes in the supplier system, it looks like additional engineering work had to be carried out following the installation on the 13th and that was sorted this afternoon. As the order is still open I've got in touch with our suppliers and they've manually got the order completed in its entirety now.
Unfortunately there's another issue which is different from the above and this is a system issue affecting your account, which means we can't activate your account to allow an internet connection through or generate any bills.
As a 'fix' we'd need to set up a new account and transfer your order details across, activating it straight away. Could I arrange for somebody from our customer options team to call you back and arrange this? If you're happy with this what would be the best time frame for a call? I'll also make sure the offer you've signed up on i.e. pricing/any cashback is honoured.
Apologies for the inconvenience this causes.
Fixes: 815
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
