How long does activation take?
FIXED- Subscribe to RSS Feed
- How long does activation take?
02-10-2018 11:55 AM
Fixed! Go to the fix.
02-10-2018 7:33 PM - edited 02-10-2018 7:33 PM
Hi there.
It looks like your broadband order completed at 17:50 today so I've pushed things through on our side now.
If you set up your router in a couple of minutes you should be up and running.
Let us know how it goes.
Re: How long does activation take?
02-10-2018 8:25 PM
Brilliant - thank you Gandalf! Always the best wizard - better than Dumbledore any day.
02-10-2018 8:44 PM - edited 02-10-2018 8:44 PM
No problems at all and I'm glad to hear that, but don't let @Dumbledore hear you say that.
03-10-2018 3:28 PM
Your name appears to be 'Gandalf' but your profile picture says otherwise.....
What sorcery is this?
04-10-2018 9:22 AM - edited 04-10-2018 9:50 AM
Ssshhh, I’m in disguise. 🧙♂️
15-10-2018 1:32 PM
Hi, I have a similar scenario.
I'm also changing from BT. I received a text very early this morning to say that the phoneline is active but nothing regarding the fibre.
Should I expect another text regarding the fibre and if so how long does this normally take?
Just wondering as pretty much everything we do is via the internet - TV, Heating & hot water, Security etc
Any help welcome.
15-10-2018 2:18 PM
My broadband was switched on the evening of the day my phone was transferred - if that helps.
15-10-2018 2:56 PM
That does thank you... did you get a separate message to confirm the fibre?
Just wondering as it says not too plug in the router until confirmed so I'm not sure if I am waiting for another text as I have only had one to confirm the phone line is active
15-10-2018 6:09 PM
