How long before Plusnet profile matches BT?
- Re: How long before Plusnet profile matches BT?
15-07-2015 9:16 PM
Atm by Plusnet profile is about 6Mb behind BTs IP profile.. BT at 51 and plusnet at 45
Message 1 of 7
(831 Views)
6 REPLIES 6
15-07-2015 10:23 PM
The PN profile is supposed to be updated a few times a day I think. From my experience, it has nearly always updated the day after any change, if not sooner.
Message 2 of 7
(405 Views)
15-07-2015 10:26 PM
ok cheers
Message 3 of 7
(405 Views)
17-07-2015 10:06 AM
Message 4 of 7
(405 Views)
17-07-2015 5:20 PM
yes mate cheers.. well matching BTs at least.. neither are accurate 😕 48 instead of 52.. but near enough
Message 5 of 7
(405 Views)
17-07-2015 8:37 PM
Two days ago you said the BT one was 51. Now you say 52, and the Plusnet 48 suggests that has been updated by one around 48.
Are you turning the modem off at night, or re-sync'ing it now and then, or is the connection going down occasionally? If the latter, there may be something needs looking at.
Message 6 of 7
(405 Views)
17-07-2015 9:31 PM
I had G.INP enabled, then current router/modem settings weren't suitable, so I adjusted, so yeah there has been reconnects.
Pulled the dsl cable earlier too instead of a cat cable, so synced again since the post even higher @ 53.7.. but line is perfectly stable, just wondered how long it takes for Plusnet profile to catch up with BT's
Message 7 of 7
(405 Views)
