How is a phone line installed?
galthop
Hello. I've signed up for plusnet fibre broadband and it is being installed in a couple of weeks at a house I've just moved in to. Plusnet say I need a new phone line which they will install. The previous owners had sky internet and the house has a line connected to a pole in the street. The wire from the pole goes through the wooden front door frame to a phone socket inside.
I'm having double glazing installed and they will rip out the door frame and probably break the phone wire. This will happen before plusnet install the broadband. Will plusnet connect a new wire to the pole in the street?
12 REPLIES 12
rongtw
Fixes: 12
Re: How is a phone line installed?
Plusnet will not connect the wire ,, But work should be done by BT openreach , or one of their teams Thumbs_Up
if i remember Sky use the BT line for their internet so should be fairly straight forward
galthop
Thanks for the reply.
Will plus net arrange for the wire to be connected or do I need to do it?
Does it matter if the old wire gets chopped off when the door frame is replaced?
Sorry for all the questions. My old house has virgin cable so I didn't need to worry about phone line
rongtw
Fixes: 12
Hi , yes plusnet will arrage for a engineer to call to your house and carry out any work needed Thumbs_Up
Fixes: 49
The double glazing firm should be responsible for NOT braking any wires. When I had mine done they replaced the door bell.
notmyname
If the dropwire must be cut/damaged, I'd ask the glazing firm to cut the cable with as much slack as possible and leave it coiled.
Will be a nice easy job for the lucky engineer who gets your install.
galthop
Thanks all.
Fixes: 1,600
Mind PMing me your account username so I can take a look at things from a staff point of view?
Cheers
Anoush
Fixes: 1,600
If the engineer attends your property as part of the installation, I'd expect the engineer to repair the dropwire. If the engineer doesn't require access, then we'd need to raise a fault report to Openreach - that brings a risk of a £65 engineer fee.
At the moment, it looks like an engineer will visit your property. We'd send you notification if Openreach advise us that no access is required.
Let us know how it goes.
galthop
The double glazing fitters were very good, they cut the old frame so the the wire wasn't damaged and the put it around the new frame.The wire is going to a small bt box on the wall.
Fixes: 1,600
That's good to hear, let us how your activation goes.
galthop
It all went very well. The engineer came out and did his thing and I have working internet and phone.
Thanks for your help.
Fixes: 1,600
Fantastic news Thumbs_Up thanks for letting us know
