How frequent do disconnects have to be before Its worth raising a fault?
- How frequent do disconnects have to be before Its ...
- « Previous
- Next »
Re: How frequent do disconnects have to be before Its worth raising a fault?
05-07-2019 7:02 PM
Hi @SteveA
Thanks for keeping us updated. We normally expect firmware requests to be actioned within 2/3 working days, but I'm sure @adamwalker will keep you in the loop as to when that's been done.
Best wishes
Dave
05-07-2019 7:08 PM
I only noticed it was on the ceased list because it did a restart out of the blue and I noticed that the firmware hadn't updated
13-07-2019 11:18 AM
Router still on ceased list.
Software still 4.7.5.1.83.8.226
13-07-2019 3:00 PM
Sorry for the delayed update, we've added your router to the hardware management platform.
Once you've carried out a factory reset, you should be on newer firmware within a few days.
13-07-2019 3:40 PM
OK - I won't be doing that until I'm off call next week as I'll have to reconfigure it once its been reset.
13-07-2019 3:45 PM
16-07-2019 8:10 PM
So its upgraded to 4.7.5.1.83.8.263
And the network discovery bug (https://community.plus.net/t5/My-Router/Software-version-4-7-5-1-83-8-237-2-2-No-devices-showing-on-... ) is still partially present in that it doesn't properly see devices on the wireless connections
There are currently 2 phones, 2 laptops and a printer connect via the Wireless connections
(although it does seem to find things on the LAN sockets which was the main problem as without those you couldn't do port forwarding)
16-07-2019 10:17 PM - edited 16-07-2019 10:30 PM
The 5GHz network seems to be pretty much dead - I can connect to it but there is just about no throughput, android throws fits about it, my linux laptop just sulks.
When I'm on the 5GHz network ping just hangs
I'm not using the router for DNS
Starting to wish I'd not upgraded the firmware now.
16-07-2019 10:39 PM
And my phone, even though its connected to my 2Ghz wifi, keeps telling me I'm connected to a BT hotspot and need to sign in.
16-07-2019 10:52 PM
Apparently the 5GHz issue is a known problem.
- « Previous
- Next »
