How do you improve Video calling (e.g. FaceTime)
- Re: How do you improve Video calling (e.g. FaceTim...
03-01-2017 10:41 PM
I recently got my mum and dad onto PN 38mb fibre, in an attempt to improve their overall communication experience. Whilst download has uplifted to speeds of 32-35mb, the upload is stuck at 2mb. Consequently our FT experience is still prone to drop outs andpoor connection issues. I have the higher package and get 63mb/16mb respectively.
can anything be done to improve this for my M&D; Are there some settings ? Or is this now stuck with only a larger personal investment?
Kind regards
Re: How do you improve Video calling (e.g. FaceTime)
04-01-2017 9:31 AM
Yes unfortunatly PN only sell 38 down with 2 up unless you can get the 78 / 20 package more money of course , have a look here and put your phone in https://www.dslchecker.bt.com/
04-01-2017 9:47 AM
On a 5s it's coming in around 1meg/sec but the iPad closer to 2
04-01-2017 12:36 PM
Interaction is an IPAD AIR (me) to an IPAD MINI (M&D). It was not great on ADSL and not much better on Fibre
Its a shame that with progressive technology, the speeds aren't kept in-line with demands. You would have expected basic-Fibre to at least blast through some basic comms requirements, its not like this is a niche market with Facetime/Skype etc. There has to be a seismic shift at some point on upload speeds as my understanding that copper-wire to home has reached its financial viability peak.
2mb is just so poor!
04-01-2017 12:54 PM
Copper has a long way to go yet, http://www.increasebroadbandspeed.co.uk/2015/what-is-gfast
Bt is already rolling out trials and committed coverage plans. Be interesting to see who can use 300mb though even in a multi 4K household! Not seen anything from plusnet on g.fast plans.
04-01-2017 1:07 PM
Interesting link - thank you.
Its something I need to consider I guess, paying the extra £5, Their line is supported on the higher speed.
Cheers
04-01-2017 1:13 PM - edited 04-01-2017 1:14 PM
You should also be considering the WiFi connections to the iPads.
Splitting the 2.4 and %Ghz channels on the Hub 1 and unsyncing them will help. How far are you from the router when making the calls?
Also knowing how congested the WiFi channels are in each hose, are you using the least congested ones? A WiFi analyser will help determine which channels to use, don't use the auto setting, it does not seem to do what it says it will.
04-01-2017 7:12 PM
Good points. I didn't get into the SSID setup as not enough time, but will try to look another time.
The upload and download speeds were compared between cable and wifi with no discernible difference. I did a network health checker and all was fine too.
What is frustrating is that 2mb is about as useful as a chocolate teapot and other similar fibre products offer 8mb and above. Without too much trouble I'm sure PN could increase to 4mb to ease some of the pain on what are considered ubiquitous comms tools.
04-01-2017 7:16 PM - edited 04-01-2017 7:22 PM
The products Openreach sell are 18:2 40:2 40:10 55:10 and 80:20
So a 4mb upload isnt doable unless you pay for the 40:10 and get it capped.
If you arent doing anything else on the line, 2mb is quite a bit for facetime, if you go for 80:20 you arent going to get 10mbits/sec video streaming going off ipads.
The other thing that helps is good lighting, the front facing camera get a lot of noise in darker rooms lit with lights rather than the sun/daylight.
Just looking at the apple sight, the mini4 (not sure if thats the one you have?) only has a 1.2m pixel front camera that does 720p video, so that is also going to be a limit. Maybe next time they visit get them to try a facetime call from a different room while on your wifi and see if that improves, or if they have a neighbour to try with.
04-01-2017 7:25 PM
Thanks for info - will do all that is suggested. It looks like sky offer the 40:10 by default, as opposed to 40:2. My friend has no such issues when I FT them.
04-01-2017 7:29 PM
get your parents to facetime for friend 😉 that is where the problem issue is - is the line to slow or the ipad mini delivering the lower quality.
04-01-2017 8:53 PM
My parents are on ADSL2+ with an upload speed of about 800 kbps. Whilst the picture quality isn't that great, there aren't any drop outs. The point being that lower upload speeds will definitely affect picture quality, but shouldn't necessarily cause drop outs, which I think you said are happening.
One way to check, is to try facetime audio with them. It uses less bandwidth than facetime, and see if you are still getting drop outs. If so, there may be another issue, and not just the slow upload speed.
04-01-2017 9:00 PM
If there is nothing else going on within your network connection 2mb will be enough to do FaceTime. The problem will e with all the external issues and traffic, but as you are too busy to check, its easier to blame the 2mb upload!
04-01-2017 9:01 PM
I've not done Audio only for long enough. The couple of times we have has been ok
Clearly need to do more tests, but can't help think that the lower uplink speed is not my best friend
04-01-2017 9:27 PM
Seems like you're not my best friend either 😂
