How do you get support here?
trayler
My fibre broadband has been playing up (Speedtest was showing only about 1MB download speed), tried rebooting both the OpenReach and WiFi router which briefly resolved the issue. Shortly later the WiFi router is showing a red light for internet and after a reboot it isn't showing any lights here.
So there appears to be a problem with the line. However on the past there appeared to be a way of initiating cases online which has now either disappeared or been well hidden and trying to call support is a waste of time unless you are a big fan of hearing hold music and apologies until 10pm when the service closes
Anybody know how to get support or should I just ring through to cancel and find a usable ISP tomorrow?
Browni
Aspiring Hero
Fixes: 45
Re: How do you get support here?
https://faults.plus.net is a good starting point.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
trayler
Thanks for the link, it would be useful if they made it accessible via their support site but they obviously like to keep it well hidden.
The fact they describe themselves as having award winning support is shocking.
Fixes: 31
Its one of the first pages on their help pages!
trayler
You used to be able to access it via portal.plus.net
When I look at the help pages all I see is a limited set of questions with answers and a link to try calling them
Plusnet Staff
Plusnet Staff
Fixes: 116
Hi there @trayler
I am sorry to hear are unable to connect to the internet.
I've looked through your account and I can see your should be back online now? I'm testing your line and I'm seeing an active Major Service Outage that your circuit is affected by. Fingers crossed it's fixed soon.
As for raising a fault to us online, you can find the above link by going through our Help & Support pages at www.plus.net, apologies it isn't on the contact us page.
We do encourage our customers to run through the troubleshooting on their side before raising a fault to us.
I apologise for the inconvenience caused.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
