How do i know when my modem (plusnet Hub one)
hali39
Hi
just a random question, how do i know if i should update the hub software or if there is even a new release?
i have just seen this on the bottom of the login page would it appear that the modem is automatically updated?
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 15/08/17
thanks in advance
southerner
Re: How do i know when my modem (plusnet Hub one)
Sounds pretty current.
The Hub One generally has an automatic firmware update.
Fixes: 6
I think PlusNet push them out remotely, so you don't need to do anything.
It is not all at the same time though, so you may have to wait a bit longer than other people. I assume it is done in batches of routers over a period of time.
Unless your current firmware is giving you any problems, I wouldn't worry.
Fixes: 461
We'd push out firmware updates where/when appropriate and required.
