How do I view previous months usage?
- How do I view previous months usage?
01-02-2017 8:31 PM
When I try to view my data usage it tells me there's no data because it's a new month. I don't want to see this month's usage, I want to see last month etc. Where can I see this info?
Re: How do I view previous months usage?
01-02-2017 9:37 PM
Sorry to hear you are having issues viewing your usage.
Unfortunately for some accounts at present there is a known issue viewing usage. I am unsure at this time what time frame for a fix.
I can send you your usage if you would like. Please PM me your username and the date range you want usage for and I will put send this to you via the ticket system tomorrow.
Cheers
Pete
01-02-2017 10:02 PM
Or you could click on the usage history button if you have not been affected - got to be worth a try?
01-02-2017 10:12 PM
01-02-2017 10:45 PM
@Browni yes, I too am affected, but only in the last week or so, maybe the OP is affected, or maybe they just don't know about the link I shared - just trying to cut down options. Mind you, being on an unlimited package, I don't look at it too often!
03-02-2017 2:41 PM
Hi Havel,
As per my PM I have sent you your usage data for the last 2 months as requested.
03-02-2017 4:52 PM
@Mustrum i have unlimited as well , but still like to check my usage you never know if you have some leaches on your wifi
