How do I set up my Netgear DGND3300v2 router as a wifi extender to my Technicolor TG582n?
actualityplus
Please see above.  Technicolor TG582n already is already up and running.  I just want to be able to extend its range using the Netgear wireless-N modem router.
please keep it simple...thanks
sb4100
Re: How do I set up my Netgear DGND3300v2 router as a wifi extender to my Technicolor TG582n?
hi
you cant, that is a netgear dsl router, and has a dsl port for main connection.
buy another wireless router, run a ethernet cable and plug into the main port or buy home plugs
thanks
actualityplus
Thanks!
sukh96648
Doesn't work at all. Plugged into my computer and the setup screen doesn't come up. OK, I think, I'll use the mywifi-ext.com and mywifiext.net sites that they suggest as a backup. Neither site is live. Just connection errors.
