How do I set the Asus RT-N66U to "Always On" for PPPoE?
- Re: How do I set the Asus RT-N66U to "Always On" f...
01-11-2014 3:13 PM
I have just finished setting up a new Asus RT-N66U router for my fibre optic connection.
It's connected fine, but how do I check and make sure that PPPoE is set to "always on" (as per the plusnet guide?). The Asus set itself up and automatically detected the PPPoE but I cannot find a setting anywhere on the routers control panel.
Any ideas?
Any ideas?
Message 1 of 4
(1,627 Views)
3 REPLIES 3
Re: How do I set the Asus RT-N66U to "Always On" for PPPoE?
01-11-2014 4:40 PM
Message 2 of 4
(1,163 Views)
01-11-2014 5:19 PM
Is there a setting for something like idle timeout? If so setting that to zero will be always on.
Message 3 of 4
(1,163 Views)
01-11-2014 5:23 PM
The setting is saved once you've configured/its picked up you have a PPPoE connection.
Message 4 of 4
(1,163 Views)
