How do I know if I'm on the new network?
xreyuk
Is there a way of telling if I've been migrated to the new core yet? I'm on a static IP if that matters.
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: How do I know if I'm on the new network?
Hey there. I'm not entirely sure how you find out on your end, however I'll let you know first thing tomorrow morning when I'm back at the office. Smiley
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
rongtw
Fixes: 12
I belive if you do a tracert from the CMD someone here will tell you Thumbs Up
geekofbroadband
New network?
Plusnet Staff
Plusnet Staff
Fixes: 116
@xreyuk Your service is on the new network Smiley
 Plusnet Staff
Fixes: 180
@rongtw Customers may not see a difference on a tracert if they have a static IP.
 Harry Beesley
stoswald
Are "ALL" Static IP's on the New Network?
rongtw
Fixes: 12
No i have a Static IP and am not on new network Wink
stoswald
That's a shame. Are you still able to jump gateways on a router reboot?
rongtw
Fixes: 12
stoswald yes reboot moves gateways Thumbs Up
MattyC
Champion
Fixes: 46
Heads up that migrations to the new network are all done under the bonnet. As a result, the static IP wouldn't affect anything.
PeeGee
IIRC, the issuing of Dynamic IPs is farmed out to the consumer end of the network in blocks sufficient for the "customer count" but the issuing of Static IPs doesn't change when moved to the new network (because it's too difficult/fragmented) - also there may have been mention of Static IP connections being only via bng gateways, which would lose me 2Mbps compared with ag gateways based on the SK data I have.
I could be (and often am) incorrect, of course Crazy3
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Using a TP-Link TD-W9980 modem-router.
