How do I know if I'm on the new network?
FIXED- Subscribe to RSS Feed
- How do I know if I'm on the new network?
30-06-2016 9:07 PM
Is there a way of telling if I've been migrated to the new core yet? I'm on a static IP if that matters.
Fixed! Go to the fix.
Re: How do I know if I'm on the new network?
30-06-2016 9:44 PM
Hey there. I'm not entirely sure how you find out on your end, however I'll let you know first thing tomorrow morning when I'm back at the office.
30-06-2016 10:52 PM
I belive if you do a tracert from the CMD someone here will tell you
01-07-2016 2:58 AM
New network?
01-07-2016 6:52 AM
@xreyuk Your service is on the new network
01-07-2016 9:23 AM
@rongtw Customers may not see a difference on a tracert if they have a static IP.
10-08-2016 10:29 PM
Are "ALL" Static IP's on the New Network?
11-08-2016 6:16 AM
No i have a Static IP and am not on new network
11-08-2016 7:13 AM
That's a shame. Are you still able to jump gateways on a router reboot?
11-08-2016 7:49 AM
11-08-2016 9:49 AM
Heads up that migrations to the new network are all done under the bonnet. As a result, the static IP wouldn't affect anything.
11-08-2016 11:13 AM
IIRC, the issuing of Dynamic IPs is farmed out to the consumer end of the network in blocks sufficient for the "customer count" but the issuing of Static IPs doesn't change when moved to the new network (because it's too difficult/fragmented) - also there may have been mention of Static IP connections being only via bng gateways, which would lose me 2Mbps compared with ag gateways based on the SK data I have.
I could be (and often am) incorrect, of course
Phil
