How do I check what my speed profile (DSLAM?) is set to?
asdfghjkl
For over a year with Plusnet it was set to about 70Mbps, and I was getting results of 65-68Mbps on speedtest.
For the past few days it's 12-18Mbps.  This is on multiple computers, one of them attached to the router with an ethernet cable.
I go back to my control panel to check if the profile has been changed but I can't find that info any more.  Where do I find this information now?
bales1983
Re: How do I check what my speed profile (DSLAM?) is set to?
Would you happen to mean this one? Smiley https://www.plus.net/my.html?action=data_transfer_speed
asdfghjkl
That's the one!  Thank you.  I can't find it in any of the control panels any more.
At least it's nothing to do with my speed profile anyway:
Estimated line speed:
Current line speed:
75.2 Mb
I suppose I'll have to create a support ticket.
bales1983
Looking that way yes Sad and no ive been unable to find it for quite a while but had the page bookmarked Wink
Fixes: 204
Our tests aren't showing any obvious issues.
I'd recommend raising a fault at https://faults.plus.net
 Matthew Wheeler
asdfghjkl
Quote from: Matthew
Thanks Matthew.  Before I do this I want to ensure there are no issues with my Asus router, so I'm going to re-flash the latest firmware, reset it to factory defaults and see if the problem returns.  If that doesn't help, I'll try the Plusnet router.  If that doesn't help, I'll take your advice. Wink
