How do I check what my speed profile (DSLAM?) is set to?
- Re: How do I check what my speed profile (DSLAM?) ...
08-12-2015 8:18 PM
For over a year with Plusnet it was set to about 70Mbps, and I was getting results of 65-68Mbps on speedtest.
For the past few days it's 12-18Mbps. This is on multiple computers, one of them attached to the router with an ethernet cable.
I go back to my control panel to check if the profile has been changed but I can't find that info any more. Where do I find this information now?
Message 1 of 6
(1,344 Views)
5 REPLIES 5
Re: How do I check what my speed profile (DSLAM?) is set to?
08-12-2015 8:24 PM
Would you happen to mean this one? https://www.plus.net/my.html?action=data_transfer_speed
Message 2 of 6
(1,015 Views)
08-12-2015 8:27 PM
That's the one! Thank you. I can't find it in any of the control panels any more.
At least it's nothing to do with my speed profile anyway:
I suppose I'll have to create a support ticket.
Quote Estimated line speed:
Current line speed:
75.2 Mb
Message 3 of 6
(1,015 Views)
08-12-2015 8:33 PM
Looking that way yes and no ive been unable to find it for quite a while but had the page bookmarked
Message 4 of 6
(1,015 Views)
09-12-2015 9:53 AM
Our tests aren't showing any obvious issues.
I'd recommend raising a fault at https://faults.plus.net
Message 5 of 6
(1,015 Views)
09-12-2015 6:04 PM
Quote from: Matthew Our tests aren't showing any obvious issues.
Thanks Matthew. Before I do this I want to ensure there are no issues with my Asus router, so I'm going to re-flash the latest firmware, reset it to factory defaults and see if the problem returns. If that doesn't help, I'll try the Plusnet router. If that doesn't help, I'll take your advice.
Message 6 of 6
(1,015 Views)
